reverse polarity
  • 2
SkyHolder
Im guessing someone has did this same thing. I have no excuse but, not paying attention to what I was doing. I connected my Pioneer AVH-P1400DVD in dash player with reverse polarity, It sparked a bit and now it does not work. Does this mean its trash or can I salvage it ? Actually what had happened I was changing coach batteries in my motorhome from a single 12v deep cycle to, two 6v golf cart batteries. The radio was hooked to a hot wire so it would play with out the key on. The battery cables were not identified well (red and black) and they were installed in reverse. When the cable sparked I realized my mistake. Now I need to have it repaired or buy a new one. Does anyone know what I might have blown out, maybe a fuse. I appreciate any assistance to this problem.
There should be an online fuse behind the deck on the power wire try that. If not time for a new one. This is why I like color coding with heat shrink of the wires are the same color.
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
I bought a 2023 Mitsubishi Strada, known in most parts of the world as a Triton. Although it's 2023 it hasn't changed for a few years and this...
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
255
SkyHolder
SkyHolder
Naples,Florida
dbjunior
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
