Ring terminals...how do i use em'??
Donks
CO, Ohio
i got the 2gauge ring terminals......and i wanted to know is there a certain way 2 clamp down on them...i heard there a certain way to clamp down on them to get the wire to stay perfectly on the ring terminal
Or am i just trippin' and i can just use some pliers??
Nah......I do not do it that way........the crimp tool is spendy
I use a torch and a roll of solder place terminal in vice,heat well and feed solder into
terminal till filled with liquid solder to about 3/4 to top,insert cable and wait about 20 sec's...
heat shrink and rock on
I used to do this, but had one slip. now I crimp while solder
bench vice to clamp it then i take something with a point (dont know what the **** its called but almost like a chisel with a single point) and give it a good couple taps with a hammer to make a dent right in the middle, never had a wire done like that come out.
center punch
Heres is a video of how I do it,only I use solder and not a preformed pellet
That is a bad ass video. That video should be put in a stickied thread. That is exactly how I have done mine, except I use spooled solder, paste flux, and a razor blade to cut the wire jacket. End result is the same though.
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
739
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Donks
Donks
CO, Ohio
Ignatowski
    Jun 1, 2024
    May 31, 2024
