Rockford Fosgate 1200D PROTECT MODE!
  • 1
Duedle
I have this weird scenario that whenever my vehicle is turned on and in park my amp has a blue light on meaning it is working, but whenever the vehicle is either moving forward or going in reverse the red protect light starts blinking. I has 2 Rockford Fosgate P3's in a ported box wired to 1 ohm and i checked the terminal cup resistance and it is in fact wired to 1 ohm but i cant figure anything else out that can be causing the amp to enter protect mode while moving?
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Duedle
Duedle
Tampa, FL
Duedle
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
