Rockford fosgate amp & infinity reference 1262 sub
  • 4
destructor10
4
Mumbai
I am planning to install a mono amp & sub in my car. I would need your suggestion, if the said amp & sub together would be able to run based on their individual config. Also, if thier are any other better sub & amp in the same category and price point.
Sub
Infinity 1262w Reference Series 12" subwoofer with dual 4-ohm voice coils at Crutchfield.com
Mono amp
Rockford Fosgate R500X1D Prime Series mono subwoofer amplifier — 500 watts RMS x 1 at 2 ohms at Crutchfield.com
Below is my current setup:
Amplifier
Pioneer amp - 750 watts - 4 channel
GM-A6604 | Pioneer IndiaPioneer India
Front speakers - component speaker with tweeter
db6501 - Polk Audio
Rear speakers - co-axial
db691 - Polk Audio
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
destructor10
destructor10
Mumbai
LosIsATool
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
