Rockford Fosgate Amp
  • 6
96CivicEXRican
Please recommend me a decent Rockford Fosgate Amp for my highs. Nothing too over the top just something good enough for some nice clear voices.
I have a 4 channel blue Orion amp but only one channel is working right now and I have 2 speakers going to the one channel and everything sounds like straight CRAP! Although everything in the headunit is tuned correctly....pissing me off...seems like bass is coming through the speakers or something. What can I do to fix that, if anything?
Try the RF T400-4. I use it and it works really great for mids and highs. Any amp will do as long as the build quality is good and it does it's rated power. You will hear very little difference if any between amps.
Why not the 4 channel RF Prime amplifier for the budget conscious?
My only problem is I always tend to pick the least efficient 6.5" drivers known to man and 50 watts RMS per 6.5 is not enough for me.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
96CivicEXRican
96CivicEXRican
Buffalo, NY West Side
SicAudio
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
