Rockford Fosgate P2 (discontinued model)
  • 2
BigHead26
Okay so I have two 12" RF P2's but both of them have the same problem. The voice coils on the subs keep coming apart , the glue keeps coming off cause of the heat?theres no real physical damage to the coil besides that. They're in a sealed encloser powered by a Kenwood excelon x500-1 mono amp. Am I over powering them? What could be the problem for the constant glue problem.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
BigHead26
BigHead26
San Antonio, TX
CrossoverOre
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
