Rockford Fosgate PBR300x4 BNIB
  • 4
naughtyca
Tampa FL
75 watts per channel x4 @ 4ohms BNIB never hooked up
Here's sonic's link for specs
Rockford Fosgate PBR300X4 300W RMS 4-Chan Class D Punch Amplifier
$110 shipped
http://i1147.photobucket.com/albums/o549/mainard1/20130425_065817_zps6683c456.jpg
Does this really not have RCA inputs?
It does have RCA, there is a connector included that you connect the rca and the connector connects to the amp, same with Power and speaker wires, this makes it easier to install.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
naughtyca
naughtyca
Tampa FL
MagicOnTheTire
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
