Rockford Fosgate Punch P3 P312D4 subwoofer
  • 1
Wingman0121
1. Product:
Rockford Fosgate P312D4 dual 4 ohm voice coil subwoofer with trim ring.
2. Specs:
Dual 4 ohms, 500 watts RMS, 1000 peak.
3. Description/Condition:
In pretty good cosmetic and working condition, it wasn't used a whole lot and actually sat in a closet for the past 2 years. From some angles you can see what looks like fingerprints on the underside of the clear dustcap, someone at the factory had dirty fingers when they assembled this unit.
4. Price: :
$100 plus shipping. If you come pick it up then you can get a FREE Q-Logic ported box (last photo, sorry for the bad focus), I live in Stevens Point WI. It could use a new front baffle but the old one works, it just have a lot of holes in it.
5. Pictures:
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
Wingman0121
Wingman0121
Wisconsin Rapids, Wisconsin
Wingman0121
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
