Second post - Help with 12" Kicker free-air sub
Hiya all,
Has anyone any specs on box sizes for the Kicker 12" free-air subs.
I am looking for a box with a nice and low extension with a resonating freq of about 20-30 Hz.
Thanx all,
The stressed one .
all right check it out i used a old box for 2 jl 12's w0's and i'll tell you what i never knew that kicker freeairs could pound, slam ,kick, and thump so loud & you also get that low shake your bon bon thing if you know what i mean.
if they are free air subs your don't need a box...just mount themonto a peice of mdf with holes in it for them to sit in..i think, someone correct me if i am wrong, but i beleive thats the whole point of free air subs, no box required....
You are 100% correct - in the normal installation. I'm doing things a bit different - I already have 2x 8" Infinities running in a free-air mode in the trunk - if I add in the 12" I'm sure the 8s will flap and distort. I kinda plan to put the 12 in a seperate box firing into the cab.
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
So, why the fukk is the pedo replying to me? He started the shitt again and I am responding. What don't you understand?
75
9K
Yes. Ring terminals will work great. crimp them pretty good. You can hit with solder to make a secure solid connection, and then Heat shrink over...
458
Stressed_Eric
Stressed_Eric
South Africa
97_jeeper
    Jun 1, 2024
    May 31, 2024
