SI sql 15
  • 6
Ridinhi
Not really a build log(yet) but just wanted to show a couple of pics of this sun I got today. When the time comes, it will be sealed. Want opinions on if I should try pairing it with two passive radiators? I’m looking at the 15” radiators from Dayton audio.
Id probably get a set of earthquake radiators. 2 high excursion 15inch radiators will be difficult to find. Typically you want each radiator to have at least 3/4 xmax of the sub
2 of these would be perfect and probably space saving though maybe a bit expensive
Or these
Anything’s possible. If I could come up with some plans, I’d attempt it!
Let me ask you guys, what if I where to do a build with the si sql facing rear of cab with the radiators downfiring? Console between seats. Think it would work?
Or these
These are adjustable, the earthquakes are not.
That seems like enough room, I'd be interested to see how this type of setup works.
What do these subs require as far as air space?
The sql requires 2 cubes sealed. As far as the passives, that’s where I will need help. I thought I would just add them to the 2 cubes but I’m not clear on all this.
The more I look into this, the more I’m thinking this will not work. I may just wait and do this setup some other time. Or, just try it without tie radiators.
Excellent choice on the SSA Evil's. :)
28
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
3K
Those pair of 12s with the right enclosure and tuned as well as powered properly should perform much better than the single 15, provided you have...
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
5
Ridinhi
Ridinhi
Winston-Salem, NC
SlugButter
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
