Silverado people
  • 6
johndoe1234
Mesa, AZ
I have an 04 silverado regular cab and was wondering where everyone runs their power wire from the battery?
I have 1/0 gauge wiring and it doesn't look like it will fit through the stock grommet that runs through the firewall. Anyone have any ideas/suggestions?
drivers side grommet. Poke a hole through and spray some wd40 and the 1/0 will slide thrugh it. I tape the 1/0 to the end of a straightned hanger and push it through the hole. Just be careful not to puncture the factory wires. This is a pretty easy truck, you shouldn't really have issue with it.
I ran my 2 0/1 along the frame, then I drilled a hole in the floor for them to come through with a gromit from ace hardware.
IF you do this, I would cover it with some split wire loom to help protect it from the elements. If you can, zip tie it to the frame to keep it from hanging also. I wouldnt go this route though.
Do as said above and poke a hole in the driverside grommet. Thats what I did.
That is what I did...came through a factory grommet in the floor on the passenger side...and yes, covered the wires with split loom from the battery to the grommet...helluva lot easier than trying to come thru the firewall...my Silverado is an '08 X-Cab.
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
568
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
7K
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
9
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
johndoe1234
johndoe1234
Mesa, AZ
AlterEgo99
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
