Simple question, only need a simple answer.
  • 5
IronAnRkst
Surely this has been asked before and surely there is plenty of different opinions, but if I am planning to put 2 12's in my car and change the door/rear deck speakers to aftermarket, would I really need an amp on the door speakers or would much difference be noticeable with the subs..?
if you put 100 watt RMS aftermarkets in without giving them juice, it'll sound like shiet, i'd recommend a door treatment and a good amp. Yes with a proper sub in proper box and quality amp, you'll notice a huge difference. Put in good effort in the installation part and it will sound good. Read up on how to make a good seal and deaden doors.
If you amp the mids you'll notice a very big difference in sound quality especially when turning up the volume. If you don't amp them and you turn the volume up about 3 /4 of the way you're going to hear a lot of distortion.
Big difference in sound with an amp going to them.unless you have people in your back seat, I'd Just upgrade the front.have the rears running off the headunit.
I would run a pair of 15s in an suv.. or run 4) 12s
24
3K
I think it is the input sensetivity. Indicating you can wire direct ftom speakers.
21
3K
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
6
IronAnRkst
IronAnRkst
Brunswick, GA
IronAnRkst
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
