simple speaker wiring (adapter?)
usenet4life
12
gta, on
I am purchasing some new speakers, (infinity 6010cs) to replace my stock speakers. The new speakers just have two prongs (look like scoops) and my current speakers have plugs, here is pic:
My question is, can I buy an adapter, or can I just splice the wires somehow? HOw do I do it, there are 4 wires (I belive), and only two prongs? The most important thing I don't know is which wire goes where.
Thanks.
I'm not sure what you guys mean still as if I cut off the plug, 4 wires would be sticking out. There is only only 1 spade lug connection in the speaker . SO how do I make the connection? WHich wires go where?
It does not come with tweeters, but there are tweeter grills and there is another cable with a tiny plug taped to the door right behind the grill is so I guess it is for the tweeter.
Could be there was an amp strapped to the back of the speaker as well.
Try hooking up one set and then the other to the speaker and see which sounds best to you.
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
6
I would run a pair of 15s in an suv.. or run 4) 12s
24
3K
No Issues out of my CT Sounds amps..EQ, 6.5s. There is not one company out there that hast ever had a perfect QC run that I can think of.Hard to...
8
usenet4life
usenet4life
gta, on
johnecon2001
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
