Single 12" Sub Recommendation - ~1200w RMS @ 1ohm
  • 4
schwol
CarAudio.com Newbie
21
Number of subs preferred: 1
Size preferred (if configuration allows): 12"
Budget: ~$200-$250
Power to be used (which amp(s), include which resistance): SoundQubed S1-1250 (1260w @ 1ohm or 860w @ 2) Will use it at 1ohm cause why not?
Space available (take measurements, do not guess): Sedan trunk, 30"w x 14" h x 16"+d
Goals: Anything better than my CompR
Listening habits: A good mix of rap and metal
Preferred brands/subs/whatever: None
Considerations:
NVX VCW122
SoundQubed HDS3.112
American Bass XFL
I realize the types of music I enjoy are a bit contradictory. Is there a middle ground to be found? If I had to pick, I'd lean towards making sure my metal doesn't sound like crap. I don't know which other brands/models I should be looking at.
Edit, I see Skar has some enticing options considering I'd rather avoid trying to build my first box right now if I can.
https://www.skaraudio.com/collections/evl-series-loaded-enclosures-and-subwoofer-bass-packages/products/skar-evl-single-12-inch-loaded-subwoofer-enclosure
https://www.skaraudio.com/collections/sdr-series-loaded-enclosures-and-subwoofer-bass-packages/products/sdr-2x12d4-dual-12-inch-loaded-subwoofer-enclosure
xfl is a great dependable sub everyone that has them likes them.. look at wolfram AG they $189 on presale now be in around july i ordered 1 it's a awesome looking a sub anyway
roger that, just got one from sonic electronix for $189. thanks for the help
18
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
333
Yeah I’m up ****’s creek. OP has gotta be more specific about his equipment and what he wants, IMO. 10’s take different boxes, so it’s hard to...
9
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
schwol
CarAudio.com Newbie
schwol
BOOMINGRANDPA
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
