Single 12" Sub Recommendation - ~1200w RMS @ 1ohm
  • 4
schwol
21
Number of subs preferred: 1
Size preferred (if configuration allows): 12"
Budget: ~$200-$250
Power to be used (which amp(s), include which resistance): SoundQubed S1-1250 (1260w @ 1ohm or 860w @ 2) Will use it at 1ohm cause why not?
Space available (take measurements, do not guess): Sedan trunk, 30"w x 14" h x 16"+d
Goals: Anything better than my CompR
Listening habits: A good mix of rap and metal
Preferred brands/subs/whatever: None
Considerations:
NVX VCW122
SoundQubed HDS3.112
American Bass XFL
I realize the types of music I enjoy are a bit contradictory. Is there a middle ground to be found? If I had to pick, I'd lean towards making sure my metal doesn't sound like crap. I don't know which other brands/models I should be looking at.
Edit, I see Skar has some enticing options considering I'd rather avoid trying to build my first box right now if I can.
https://www.skaraudio.com/collections/evl-series-loaded-enclosures-and-subwoofer-bass-packages/products/skar-evl-single-12-inch-loaded-subwoofer-enclosure
https://www.skaraudio.com/collections/sdr-series-loaded-enclosures-and-subwoofer-bass-packages/products/sdr-2x12d4-dual-12-inch-loaded-subwoofer-enclosure
xfl is a great dependable sub everyone that has them likes them.. look at wolfram AG they $189 on presale now be in around july i ordered 1 it's a awesome looking a sub anyway
roger that, just got one from sonic electronix for $189. thanks for the help
18
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
400
Yeah I’m up ****’s creek. OP has gotta be more specific about his equipment and what he wants, IMO. 10’s take different boxes, so it’s hard to...
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
schwol
schwol
BOOMINGRANDPA
saints747
    May 7, 2024
saints747
    May 7, 2024
