Skar
  • 5
spike03585517
CarAudio.com Newbie
I am fixing to run (2) Skar VXF 12's, 1 ohm in a ported enclosure. I am currently running (2) Skar SDR 12's, in the loaded enclosure on a Pioneer GMDX 971, roughly 1,200 rms. The SDR's sound great, but I believe the VXF's will be better. I currently have the Mechman 240 amp alternator, and 1 XS 3400 under the hood. Wanting to get the JP 23 amplifier on DFS for the (2) VXF 12's, would this be enough to power them, but not over do it? Did not want to go with a bigger amplifier, didn't think my current electrical would be enough. WYT?
They said the jp23 is underrated. I believe certified power was something like 2,300-2,500 rms.
The box will make the most difference. Looks like the VXF is 1500 rms so you will definitely be underpowering them. I personally would go bigger since box rise won’t give you the true amp rating.
SIA3500 or Cab45. I've never ran the Cab amp but it gets a lot of love. Your electrical is fine and you don't want to underpower those subs. Just buy one amp and be done with it.
I'm powering 2 XFL 12s (1500w RMS) with a JP23. it gets very powerful and shakes the entire car (99 Avalon).
Just wanted to chime in that the JP23 can get subs moving.
The VXF’s are Skar’s best woofers. I’d put 3500-4000 watts net to them. Use their recommend box size, I’d do 16 in^2/cube of port area, and I’d tune those woofers to something like 28-33 hz, personally. I’ve designed several boxes for those, and they really seem to perform and make people happy.
Some of Skar’s woofers are questionable. Some of their t/s parameters are ridiculously off, and it seems very unprofessional and lazy. The VXF’s just seem to be a different type of Skar woofer all around, IMO.
11
492
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
966
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
868
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
spike03585517
CarAudio.com Newbie
spike03585517
Mississippi
Buck
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
