Speaker and Amp Setup???
  • 3
I have a KenWood kdc - x891 head unit with three sets of preamp outputs (front, rear, sub).
I want to power these 6x9's with a concept cc-1252 amp
Concept Amp Specs:
RMS Power 125W x 2 4 Ohm
Signal-to-noise ratio: 100 dB
Frequency Response: 5Hz - 50kHz
18dB per octave crossover
Input sensitivity: 200mV - 4V
Im already powering my Memphis M3 subs with a Memphis 1000d.
My question is can I power my 3.5 speakers with the head unit as my front speakers and my 5.25 speakers with the head unit as my rear speakers and still use the rear pre amp output from my head unit to the concept amp to power my Polk db691's??? And will the concept amp blow my Polk db691's?
technically it will work
but i wouldnt reccomend it if your mids and highs off the deck will distort and your car wont sound right youll never be able to properly tune your car
change out your 125x2 and add a 4 channel amp or a 6 channel
best set up for you would be to be to go with a component sets for your fronts and rears i dont use 6x9 a lot unless its just a factory replacement you should look into that route
front 5.25 component
rear 6.5 component with plate to adapt from 6x9
sub to subs
use a 4channel amp on your fronts and rears youll have better control and crossover
^^ yes as u can distort any speaker in the world. If he sets his HU to say 30-50 I doubt his HU will send a clipped signal "not full proof" but I am 99% certain. Then match the amps gain to the HU preamps volt set at the volume you will use as your HU's max number and boom sub will play as intended and the door speakers will also do the same. Will the door speakers be drowned out by the bass well yes but it will wrk without a single issue till my man can afford to amp the door speakers.
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
651
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
558
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
You tried the external relay with no success? If so, how did you wire it?
18
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
MonteCarlo-Dice
MonteCarlo-Dice
Memphis, TN
MonteCarlo-Dice
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
