speaker making a horrible noise. not alternator whine
  • 1
ft2lewis
I picked up a 2000 ford lightning about two years ago that already had a stereo system installed. Recently i took off the kick panels on the doors to put new vinyl on them. during the process i removed the speakers and tweeters and kept the crossovers in the door. Ive also done some window work replacing both the motors and regulators. A couple of weeks ago my driver side door mid developed an extremely loud tone. It typically only makes this tone after Ive been listening to music for a while and it does not sound like the typical high frequency alternator whine. the best way i can describe it is if you spoke the number one and just carried out the "ne" at the end of it indefinitely. i have no idea whats causing this sound and it doesn't seem to affect the tweeter coming off of the same crossover. with all of the work ive done to the panels and windows my gut tells me its something inside the door and isolated from the headunit and amp. any guesses would be great as a visual inspection turned up nothing. thanks for the help
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
255
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
356
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
324
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
ft2lewis
ft2lewis
honolulu, hi
ft2lewis
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
