speaker sizes
  • 4
josh b
i'm about to buy a 95 plymouth neon but i need to change the mains out. i want to put MTX mains in as the replacements, the only problem is size. i can switch the 6x9s in the rear but the fronts are 6 3/4s and i can only find 6.5s in MTX. would the 6.5s be able to fit in the 6 3/4s hole? any help would be appreciated. thanks.
well dude, you have been mistaken, i did some research and the fronts in your car are actually 6.5s, so yes, the 6.5s you wanted will fit
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
266
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
364
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
331
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
josh b
josh b
Colorado
Baller492
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
