Speaker volume keeps on fluctuating
  • 4
ianik777
CarAudio.com Regular
131
6
Mauritius
Hi all,
encountering a really weird issue whereby when i listen to my music while driving, after some minutes, the 2 left speaker plays louder than the right one. sometimes it stays like this till the end of the trip but sometime return back to normal. note that sometimes it plays louder on the 2 left speaker, sometimes on the 2 right speaker, sometimes only on the left back speaker and so on, and on forth. even, sometimes when i press the brake, the speakers shift to the left or right and when i accelerate, it returns to normal.
P.S: when i say the volume shift, lets says i've put the volume on 15. when it shift for example on the left back speaker, the latter plays level 20(even higher than that i set) and the other 3 speakers plays on level 5. so you mostly hear only the left back speaker as it plays louder than the other 3.
has someone encountered the same issue or can someone help?
I would check all your wires, test RCA's, test speaker connections to your head unit or amp, whichever you use, also check they are in phase.
I beg to differ... Been doing this for 40 years. I worked in a bike shop for years did tons of braze joining, yes, welding. Heat is heat and...
30
426
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
245
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
768
I'd be willing to pay for a quality HU, if it meant that I can truly get the sound quality I need. I've seen some aftermarket ones that look...
10
789
ianik777
ianik777
Mauritius
1aespinoza
winkychevelle
    Apr 27, 2024
audiobaun
    Apr 27, 2024
Latest topics
