Speakers Amp and Sub!!!
  • 1
Trailblazers
CarAudio.com Newbie
I have an aftermarket stereo and I recently added an amp (JL Audio RD900/5) and sub (JL Audio HO112RG-W3v3). The installer set the gains, but the speakers are low in my opinion. Before I installed anything 18 was loud enough to listen to music. Now that I’ve added an amp and sub I need to at least put it on 19 or 20 to get good sound. The speakers aren’t loud enough and I have new components installed. The installer didn’t reset the equalizer on the head unit prior to setting the gains. Could it be I need to increase the input sensitivity or filter frequency?
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
3K
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
You can use two front channels to power the full range speakers, then use the rear channels to power a sub. IMO, for that price I would rather use...
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
337
It also lowers the amps efficiency and raises the current draw.
5
475
Trailblazers
CarAudio.com Newbie
Trailblazers
Trailblazers
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
