Speakers making a buzzing noise
  • 4
You have a ground loop. I believe there is a sticky on this issue, but it is most commonly caused by a potential difference between that the source (HU) references as 0 volts and what the amp references as 0 volts
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
4
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
5
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
192
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
182
Shaman622
Shaman622
New Britain, CT
disturbed471985
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
