Speaket upgrade (3 way VS 2 way active)
  • 2
Moose44
Hey all,
I'm attempting a budget SQ build in my 2017 LTZ Colorado and I'm unsure what to do for front sound stage .
My initial plan was to replace stock 6x9s with ALPINE 6x9 components and run them in full active configuration with 300 watts rms to the speakers and 90 watts rms to the tweeters and call it a day
But I'm wondering if there would be any improvement in SQ by adding a pair 3.5" Dayton Audio coaxials for mid/high range stuff and keeping the 6x9's for midbass ? The 3.5's will go in stock dash locations
The speakers will be powered by 2 Alpine 4 channel amplifiers both rated @ 90w x4.
The only thing stopping me from doing a fully active 3 way is my DSP which is an Audison Bit Ten .
With a good dsp, tuning, and quality drivers absolutely. I was planning on doing a 3 way setup until I priced getting my pillars built to look factory. Then I decided 2 way would be enough 😂
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
447
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
559
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
767
Moose44
Moose44
Australia
    May 16, 2024
    May 16, 2024
