Starter system under $300?
  • 3
superquest
Just ordered my son's system for his 97 Avalon. I went with Kenwood KDC-352U as my HU. My mono sub amp is the Pioneer GM-D7500M (400 watts rms at 2 ohms). It's powering a single 12" dual 4 ohm Pioneer TS-W309D4 in a 1.15 cubic sq ft sealed box. Using a 4 gauge amp wiring kit by The InstallBay AK4 (it was rated a 4.4 out of 5 by 67 users). As far as the factory 4" component sets that are in the front and back doors and the factory amp that pushes them they'll have to do for now (out of funds).
So my friend says for $300 or less I might have been able to do better. So would like to see what you guys can come up with using all new quality stereo equipment build me a complete 400+ watt rms bass set up including a HU as well.
including a head unit, less than $300 probably not especially since you want all new with all install accessories. maybe if you got a couple things used you could.
Thanks for your response guys! I'm not so much involved to justify an LTO,car is a daily driven and batteries will be installed when needed.Maybe...
4
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
492
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
935
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
962
superquest
superquest
Pataskala,Ohio
fasfocus00
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
