Stock radio with subs?
  • 3
Mattice
SC
I have a 2007 Honda Civic SI which has a factory radio wired to a factory amplifier powering an 8" factory subwoofer along with the 4 other door speakers and 2 tweeters.
I have a 1700 watt rms Hifonics Brutus Class D monoblock amp along with 2 12" Kicker subwoofers powered at 800 watt rms each.
I want to transfer these subs and amps to my new car, although I do not want to buy a new radio and harness at the moment. By using a LOC(Line out converter) I could wire RCA plugs from my rear speakers into the new amp for my subs.
I have no idea on the specs on my factory radio, I can't find them online. However, since it already has a factory amp running the stock sub, if I use the LOC to power my new amp and subs without buying a new radio and wiring directly through it, would I have any problems?
Could I blow my factory radio running this much power on top of the factory amplifier?
Thanks in advance for advice.
If I'm not mistaken with the proper loc he could also do it post stock amplifier as well if that is easier on him. If I'm wrong let me know
I'd just tap it before the factory amp. The less stuff the signal has to go through, the cleaner it will be.
HI all, I am thinking of upgrading from the stock sony radio in my ford focus 2008 to the Sony DSX-B700. Would this be a worth while upgrade for...
Hello everyone, This is my first post , I'm a total noob and was looking for some expert advice. I bought a 2010 Hyundai ix35 with a stock radio...
Water or moisture on any Electronics is never a good practice nor a great out come of operating correctly . If you want to keep that same unit, Id...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
302
Mattice
Mattice
SC
adulbrich
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
