Stupid question: Can you use mono channel amp to power door speakers?
Depends if the mono has a full range option. Most mono amps only "support" about 15hz to 200hz and anything above it doesn't handle, if that's the case then you can't use it. A sub specific amp generally won't work with speakers.
True I just figured if he was trying it most likely the amp had a all-pass or low pass filter off option
It'll "handle" it. There's just a lot of high frequency distortion so anything above mid-bass sounds terrible.
why would you run class D on your highs anyhow. Even if you can get full range it will sound like poo poo. I have some two ch amps that will do 200 rms. Hit me up, 100 shipped for two kicker 150.2s do 220 rms on birthsheet.
xtant 1.1 amps are class d, and they sounded just fine. they are also monoblock.
I have a class D comp amp. No poo poo.
According to JL JL Audio 500/1v2 Amplifiers - Car Audio Amps & Amplifiers, no. It requires a LPF so powering all speakers is a no-go. Toss it on the classifieds and trade it for a 4 channel or something if you want to power some speakers.
So if my pioneer class d gm-d7500m amp has a lpf on it i can use it on my 5 1/4 door speakers in my 2000 Honda Accord.my amp has gain,0.6.12.bass boost, and lpf on off switch and lpf adjustable dial that varies from 40hz to 240 hz .i wouldn't mind if i could i would like to push 2 6×9 in my back deck and my 2 5 1/4 door speakers on this amp if i could until i can afford a decent 4 channel amplifier
if you don't mind having no stereo separation AND had a good way to high pass filter so that you don't destroy your speakers you could run everything off of something like that.
For future reference though, it is considered bad manners to bump old threads in online forums. We have a special mascot around here who gets posted when somebody does this.
@Popwarhomie
Damn can I hire sancho for her so she can buy me a new set of 12" Fi subwoofers?? :D
6
Yeah... check this link out. It shows the power handling of that tweeter. I'd just match the power no matter if you use the crossovers or not...
7
908
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
531
Mills561
BURR
Mills561
Palm Beach, Florida
spokey9
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
