sub+amp advice
DO NOT EVER buy prefab horseshit from ebay or anywhere!
A subwoofer is only as good as it's box.
Build one yourself, or find someone in your area to build you one.
well I know close to nothing about how to build a box, so I can't do it myself. If I go to a local car audio store would they have good boxes?
BEST thing i've read tonight man!!! and NO i wouldn't buya box from the local audio shop because it will also be a prefab unit and more than likely not built to specs for your sub(s) and/or tuned anywhere close to them either. by the way ProjectPechkin ecxcllent signature.......!!//content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
OOPS.......................SORRY FOR THE DOUBLE POST, IT'S LATE AND I THINK MY MEDS ARE KICKIN' IN ( as you might be able to tell by the **** caps lock fixation!!)
BEST thing i've read tonight man!!! and NO i wouldn't buya box from the local audio shop because it will also be a prefab unit and more than likely not built to specs for your sub(s) and/or tuned anywhere close to them either. by the way ProjectPechkin excellent signature.......!!//content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
not to mention if you buy one from a local shop it will be like 250 bucks. hit up one of the box builders on this site. youll get a better quality box built to your specs and save some cash.
guys will my car support this or do i need a cap!!!! idk!!! omg!!111!1:search2://content.invisioncic.com/y282845/emoticons/search2.gif.b407e3685eef133dbce7cac8ad3982c7.gif:search2://content.invisioncic.com/y282845/emoticons/search2.gif.b407e3685eef133dbce7cac8ad3982c7.gif:search2://content.invisioncic.com/y282845/emoticons/search2.gif.b407e3685eef133dbce7cac8ad3982c7.gif:search2://content.invisioncic.com/y282845/emoticons/search2.gif.b407e3685eef133dbce7cac8ad3982c7.gif:search2://content.invisioncic.com/y282845/emoticons/search2.gif.b407e3685eef133dbce7cac8ad3982c7.gif
who on this site should I contact for building a box?
based on nobody commenting on other things, should I assume that I've made good choices?
I can build you a box, i live in Colorado, and Utah ain't that far. If you're willing to pay for shipping. I can do USPS. It seems to be cheapest
562
It also lowers the amps efficiency and raises the current draw.
695
860
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
933
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
matador_de_sa
matador_de_sa
UT
omgheyitskenny
