Sub/amp wiring for resistance conundrum...
  • 6
To add to that, "high quality" electrical componants come with 2 main benefits. Better tolerances for values like capacitance for capacitors, resistance for resistors, etc, and in the case of mosfet and semiconductors lower internal resistance /lower switching times.
Higher efficiency amps literally gain their efficiency by using parts with closely matched values and lower resistance. The smaller tolerances reduce signal losses, tighten up voltage differences, and more evenly match evenly component in the chain so that no one part is being worked too close to its limit, and the lower resistance of the mosfet gate while open decreases energy lost as heat, or reduces idle current draw while closed.
Heat, resistance, and current draw are the main values that determine almost any electrical circuit. And all three of those are linked in one way or another. Less heat = better efficiency, end of story.
Matt
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
551
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
674
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
669
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Bellmeister
CarAudio.com Recruit
Bellmeister
Dallas
mat3833
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
