SUb help
  • 4
Chris04626
CarAudio.com Recruit
33
5
Maine
I have a 2010 ford f150 crew cab
Looking at this https://www.skaraudio.com/products/...-enclosure-VS-2X10FORD-2009-UP-SUPERCREWCAB-V
with 2 of these
Powered by
What are your thoughts? ALso looking at possible justr buying 1 sub and sitting in my back seat,
Possibly this https://www.skaraudio.com/products/evl-1x12d2-rp-1500-1d-skar4anl-ofc or https://www.skaraudio.com/products/evl-1x10d2-rp-1500-1d-skar4anl-ofc
What would you do? Any input is greatly appreciated.
The underseat box supposedly works great with only the VD 10s. It states a net volume of ~1.5 cubic feet, whereas the sub's specs claim each needs 1.25 cu. ft. ported. That is iffy mathematics, but they may have tested every combination and this combo was the only one that met standards. On the other hand, that EVL has raving customer reviews. Firsthand experience trumps theoreticals. I have a ported 10 plopped on my truck's backseat that is held by a ratchet strap for safety. It does not look tidy but dabgummit it sounds fantastic.
Do you have 10, 12, or 15? What amp do you have pushing it
with 2 of these
Powered by
I have not been impressed with the few Skar boxes I have seen. The subs would in a different box may be better. They seam to fail very easy. Most likely its not enough glue ect
with 2 of these
Powered by
If you like bass then I doubt that you will be happy with shallow mounts. What is your budget? I don't want to recommend something out of your budget.
5-600 for sub and amp. then 150 for the amp to power my door speakers. I was looking at maybe just getting a skar evl 10 or 12 bass package and sticking it in the back seat.
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Dayton would be a really nice choice as well as the SQL. I would look at a R. Sounds sub too https://www.resilientsounds.com/product-page/gold-15...
7
Chris04626
Chris04626
Maine
Chris04626
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
