Sub woofer hook up
  • 2
I recently just got into the whole car audio scene and am stumped on this possible simple situation. I have a Apline iDA-C305S series head unit. Hooked up to that is my autek 2000 watt max amp with 2 12" American Bass subs. I ran the rca wires to the back of the unit along with the ignition wire and the power wire to the battery and not forgetting my ground. They work they hit and sound good but my head unit will not control them. There are the sub woofer controlers in the setting and they don't work at all. The only way to turn my subs down is to turn the bass controller down. This makes adjusting my subs very difficult. Someone know what's going on? What I gotta do to be able to use my sub controller settings in my head unit....
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
820
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
233
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
378
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
470
roaringlion55
roaringlion55
Washington, PA
keep_hope_alive
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
