The vehicle is a 2012 Camry SE. It's my daily driver and I'm just looking at doing a simple upgrade. My plan right now is just to use a 4 channel amp. I'm going to run a set of components off the front 2 channels and a single sub off the rear. Amp and components are still undecided. I don't want to have to upgrade the electrical system so I'll probably be looking at something like a 75x4. I had been considering the Rockford Fosgate FR Prime R400-4d which says it does 75x2 and then will do 200x1@4. I know it's not a lot of power for the sub but I think I'll be happy with it. I'm open to other suggestions also.
Number of subs preferred: Single Sub
Size preferred (if configuration allows): 10 or 12
Budget: $250
Power to be used (which amp(s), include which resistance): To be determined but probably around 200 watts rms @ 4ohm
Space available (take measurements, do not guess): I have up to about .94 cubic feet to work with. Sealed.
Goals: Upgrade from OEM. Additional bass but more sound quality oriented than just loud.
Listening habits: Mostly rock, some rap. Pop when my wife is in the car. So a little of everything.
Preferred brands/subs/whatever: Open to anything
Budget: $250
