Subwoofer setup for $300
Is the rear a split bench? Like you can flip up two seats and leave one down? Because if it is and $300 is your max, id say sundown ev2 12, or hds212 get a used 500-800 amp on here(post a wtb thread youll find one) and build your own box get a free box plan/cut sheet online go to Home depot have your wood cut and glue/screw together and get a $50 amo kit online.
Im sure you can fit a 15" and only take up 2 seats and leave one open comfortably. A 30x18x18 box is 4.49 net before sub and port to make your life easier you can use an aero port. Youll have more than enough for a 15" sub are you willing to use a box that size?
Well I wouldn't want to give up the whole back seat every now and again someone mat ride in the back would it be removable.
use 3/4 birch ply, box will be light enough for you to carry and put in the back whenever you have guests.
this is the site to buy mini stuff for your box and carpet also. These terminals allow for quick disconnect. Even aeroports if you want.
Terminal Plates & Cups in the Speaker Components Department at Parts Express | 321
cheaper way to make aeroports is to buy cheap 6" aeroports from your local hardware/plumbing stores and flare it with a heat gun and metal bowl.
You'll be glad you got the 15 lol.
Exactly cone area makes such a huge difference and having the proper box will aswell.
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
417
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Plzhelp
Plzhelp
elberton,ga
C1500martin
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
