SWC wiring switch
  • 2
jmkcc
I have a steering wheel control wire that also sends horn signal. This is a modded steering wheel in my car and I do not have the OEM wiring. Basically SWC and horn receive 12v+. When the horn is pressed, it passes 12v to a module that measures resistance - if resistance is zero, it grounds the horn so it operates. If the resistance is not zero it passes the signal to the head unit as SWC.
The module will not interface with my car so I was wondering if it is possible to create some type of switching mechanism that will ground 12v zero resistance and send other 12v non zero resistance feed to the head unit. I'm not an electronics genius, but am good with sodlering gun and reworking station. So I could create a circuit board if someone can steer me in the right direction.
Thanks, JMK
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
I assume the plugs are if you have factory equipment like a amp, etc.
Hello, I just installed a Chinese Headunit and wondering for the Steering Wheel Controls if i need something else or if it should work.. On some...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
152
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
558
jmkcc
jmkcc
cape cod
JohnFoster
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
