system bought off here
aimology
So, I bought a Nice amp and 2 Subs from two respectable people. Ive been in text mode with them. I've even involved Jacob from Sundown, whom I tracked down from facebook. Awesome guy by the way. Im just looking for advice
2 10" D2 OZ Matrix Elite
Saz Sundown 1000D
Pioneer 6300BT ( ebayed )
All new wiring & RCAs ( accept on sub terminals ) Knu Koncepts with 150w Fuse @ battery
Top of the line Digital DMM VC say 2.0 each
Radio is set at custom level - all EQ bass is out -4 | mid vocals / highs are adjusted as needed
Gain and Bass boost have been turned off and full blast
This is full blast because it makes me LOL @ loud - Also, does this prier @ 2Ohm load when I was trying to tune. I put this at .5 for testing because the Flop is not as loud and I thought maybe it just wasnt beating like it was suppose to
Explain please - Any help greatly appreciated.
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I didnt think the ohm load would still be held if they were blown
not true.. there is more then 1 way to blow a sub. and i got a kicker cvr15 sitting here that will ohm out fine on both coils but its blown to fvck lol..
dont let the subs sit flat on the wood like that...ur covering up the pole vent try hooking them up individually and hold it up and run some bass threw them....also check ur wiring i think something is up
check for tears on the surrounds one of my subs had the surround lift up from the cone causing a "like blown" sound. If everything checks out they are blown like your ***** on your birthday.
Original install was a normal plug and play
gains all flat = 0
After messing with wires etc etc - I was like, why is the bass not loud @ volume 15 when my highs are.
I adjust my radio to custom and made it so 30 volume on radio was perfect out of 40 max - no EQ bass added obviously
Amp was all set to 0
I hooked up subs for 2 ohm load and 15 sounded same as 30 on subs.
talked to jacob who said put it @ .5 ohm just to see how much power the amp dishes out, should actually move them ( we were not taking into account blown subs )
so I did and the result is in video
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
213
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
623
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
aimology
aimology
Dayton,OH
oldschool4me
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
