System Build Help Please!
  • 3
RE *****. Kickers got good amps only two ohm stable though. But the ab is a lot more power for the money.
RE good or what were you trying to say? lol and the ab is def worth it over the kicker. I'll just have to save a little haha
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
For sub, I recommend going true infinite baffle. You get to keep just about all of your trunk space AND sound great doing it (if you do it right.)...
7
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
210
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
613
Sjenkins7
Sjenkins7
Ohio
NuckinFutz
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
