System Hook-Up
  • Thread starter Hooking_System
  • Start date
  • Replies 1
  • Views 1K
  • 1
H
Hooking_System
Guest
I just recently purshased a system off ebay, and am fairly new to hooking them up. I got the power cable to the amp, the blue turn-on wire from the head unit, the ground wire to the amp, but after that i am confused. how exactly are the subs hooked up? the rca wires? and in what order? thank you so much for your time.
-drew-
the rcas run from u'r HU to u'r xover or amp on the input side.
can u bridge u'r amp?
what kinda subs?
are the svc or dvc?
2ohm or 4ohm?
u get the picture. what kind of enclosure?
post that infromation and hollar at zane or ramos or stones.
but depending on what u'r subs are somebody'll get u hooked up
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
331
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
672
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
Guest
mrray13
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
