System issues!!!
Mikemootz
CarAudio.com Newbie
So I have a few issues going on. I have a 2020 mustang convertible that I've installed 1 12 inch sub with a amp and lc2i.
1st. I get random bass from sub while driving.
I have my ground secured and I sanded the area down to bare metal.
2nd. When I turn the car off my lc2i turns off but my amp stays on. I'm leaning towards a bad remote wire from the lc2i to the amp but I haven't checked yet.
Also I get a thump from my sub everything I start my car.
I’d suggest getting an amp wiring kit. Run the wire from battery to a fuse. Through the firewall to a distribution block. To the LOC.
The amp kits aren’t much and you know it’s done right
That's how I have it. I swapped out my LOC and it seems to be working fine now. That LC2i I have is about 3 years old
On the older single din alpines.the sub level had to be maxed to get full voltage.also,since u retuned your system,sounds like your door speakers...
14
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
502
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
981
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
998
Mikemootz
CarAudio.com Newbie
Mikemootz
Abilene Texas
Mikemootz
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
