[system overlook] [feedback welcome]
  • 1
bradbbeatin
2000 CHEVY LUMINA
STOCK HEAD UNIT
STARTING POINT: 12.19.12
- (x2) SPL SP315 15" 2 OHM 5600W
- (x1) SPL GLA1-3400D 3400W Max
- (x1) STINGER SGN11 20W HIGH PERFORMANCE FIXED LINE OUT
-(x1) 4 GAUGE PREMIUM POWER WIRE WIRING KIT 3000W
-(x1) SHEET 3/4 MDF
____________________________
AFTER INSTALLATION FEW DAYS PASS.. CONTINUE RIDE SAY HOUR DAY BASS NOB UP FRONT AND ALL.. NOTICED BASS NOB DOES NOT CONTROLL WELL SAY TURNED ALL THE WAY LEFT NO SUBS ARE BOOMING... BARELY TWIST TO THE RIGHT AND ****!! DOES RATTLE EVERYTHING BUT SOUNDS LIKE **** TO MUCH NOISE CAN ONLY THINK OVER POWERING LOUDNESS..
SOO....
CURRENTLY AT: 1.1.13
- AMP pulling 2ohm load
- INPUT GAIN 0.25V
- SUBSONIC FILTER SET 20HZ
- BASS BOOST SET 0DB
- LOW PASS FILTER.. MAYBE 80HZ
____________________________________
NOW EVERYTHING GAIN BOOST FILTER ETC.. ALL THE WAY DOWN.. SEEM AS IF COULD BE TOLERATED AS WELL AS THE BASS NOB CONTROLS AMP LIKE IT SHOULD..
DAY SHY OF ORDERING:
- Black 12V 35AH 1050 Watts M6/T6 High Current Battery replaces Kinetik HC800
- Chevrolet GMC Radio Installation Dash Kit + Harness + Antenna PKG224
- Clarion CZ202 CD/USB/MP3/WMA/AAC Receiver With Pandora
- 50 Feet Blue / Clear Speaker Wire 12 AWG Audio Install OFC Copper Wire Premium
- PAIR SPL AS52 5.25" 160W 2 WAY
- PAIR SPL AS-693 360 WATT 6" X 9" 3-WAY
___________________
ANY ONE CARE TO SPEAK THEIR MIND....
images of custom drop box to be reveled.. solid 3/4 construction, bracing within outer edges, 5 hour caulk job along with industrial padded tape acting as gasket solid heavy xl style reinforcing on mount side... stats to be announced..
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
284
655
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
bradbbeatin
bradbbeatin
Mid Georgia
bradbbeatin
