Tahoe cpillar wall 4 SA 18s on 8k
stupid caco isnt working for me either still im dying to see an amp there in the classifieds
frick
box flex ? ive never experienced this lol.
my build uses 2x8 structure behind 3 layers of 3/4 ply
build strong so you dont have to band aid with crappy pole bracings or thread rod
brian...that looks solid. But, i dont think Ive seen a side wall like that. Def different.
its a 4th order. 17 cubes net sealed with subs mounted regular 18.5 cubes net sealed if i mount inverted - 55 cubes ported c pillar square burb.
been following massive build since my days of window line box and horrible roof flex / noise
also found a term lab local finaly. mild n wild audio on sunrise 0 will get on a meter this week for my score
it would be a great experiment to test the sa 18 sub as is - get your scores - then spray foam the heck out of your wall / seal it off completely - make final trim pannels to fill all the gap - caulk it - let it all setup dry a day or 3 then re meter and see what improvments were made.
my guess
peak resonant hz goes up by 2 hz as well as score up by 1.5 db - but some low bandwidth may shrink up
That 5k and DD subs was only 3db under your 4 18 on 10k wall. Not a 146. It was only 4db under you at 27hz. With 2 12s. Try again
Ya u had a tiny car. Should do a 170db easy man. That shlt weak for 5k on 2 12s in a tiny car
**** I had a dd 9918 on 1500 watts in a 99 mountaineer doing 147 on music all day.
So you come on here saying you won't blow those SAs because you know what you are doing and you have a unsealed wall with 4 big *** 18s on 10,000 watts doing a 53? And you think a tiny car makes it louder? You won't find many 2 12 setups under 40hz that's louder unless it's a trunk wall.
its a 4th order. 17 cubes net sealed with subs mounted regular 18.5 cubes net sealed if i mount inverted - 55 cubes ported c pillar square burb.been following massive build since my days of window line box and horrible roof flex / noise
oh got it now....
Post up the 153db plus build u have built by yourself. I'm waiting.....
Just curious, do you have a box with ur 12's or a half wall type setup? What amp do you run? I absolutely loved my dd m4, wish I never sold it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Did you know the 1st SA 18 was tested on 2 3500 sundown amps?! And from jacob owner of sundown audio. Now ***** about that.
You may need to go to some shows and sound offs/meetings
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
that was a pain... 2.5 days probably removing everything, cleaning entire area and doing it. ive only done trunk cars before this was def a lot...
14
massivespl
Banned
massivespl
Bay city, MI
adulbrich
