tweeters blowing? need some advice please!
  • 1
Ckblood05
Ok, so im running 4 jl audio 5x7's and 2 jl audio .5" tweeters. they are hooked up to a jl audio 360/4 amp. i got the rear 5x7's each on a channel for the rear. and the front channels each have a 5x7 and a .5" tweeter. well over the past few years i blew 3-4 of the .5" tweeters. sometimes one at a time, sometimes both. i got the amp on high pass filter, gain half way & the tweets have a crossover inline to help block low frequincies. here is the link to the speakers & amp-
TR570-CXi - Car Audio - TR - Coaxial Speakers - JL Audio
TR050-CT - Car Audio - TR - JL Audio
JX360/4 - Car Audio - Amplifiers - JX - JL Audio
the 5x7's are 4ohms and the tweeters are 8ohms. im not sure what that brings the total ohm load to? but the amp is 2ohm stable. i don't have anything bridged, just both + and - wires together in each channel. if the amp is running them at 4ohms it says 70 watts a channel. if its 2ohms then 90 watts a channel. plus i keep the bass down on the head unit. surely there not getting over powered? i mean the tweeters are 50watts Continuous Power Handling (RMS) & 125 watts peak. the 5x7's are 50 watts rms & 225 watts peak. any ideas or suggestions is appreciated!!!! thank you!!!
Lesson learned, visual inspection before anything else. Wiring came undone on the drivers tweeter. I replaced them anyway, with Rockford fosgate...
17
3K
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
Ckblood05
Ckblood05
Lambertville mi.
Ckblood05
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
