speakers & amp?? tweeters blowing...
  • 1
Ckblood05
Ok, so im running 4 jl audio 5x7's and 2 jl audio .5" tweeters. they are hooked up to a jl audio 360/4 amp. i got the rear 5x7's each on a channel for the rear. and the front channels each have a 5x7 and a .5" tweeter. well over the past few years i blew 3-4 of the .5" tweeters. sometimes one at a time, sometimes both. i got the amp on high pass filter, gain half way & the tweets have a crossover inline to help block low frequincies. here is the link to the speakers & amp-
TR570-CXi - Car Audio - TR - Coaxial Speakers - JL Audio
TR050-CT - Car Audio - TR - JL Audio
JX360/4 - Car Audio - Amplifiers - JX - JL Audio
the 5x7's are 4ohms and the tweeters are 8ohms. im not sure what that brings the total ohm load to? but the amp is 2ohm stable. i don't have anything bridged, just both + and - wires together in each channel. if the amp is running them at 4ohms it says 70 watts a channel. if its 2ohms then 90 watts a channel. plus i keep the bass down on the head unit. surely there not getting over powered? i mean the tweeters are 50watts Continuous Power Handling (RMS) & 125 watts peak. the 5x7's are 50 watts rms & 225 watts peak. any ideas or suggestions is appreciated!!!! thank you!!!
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
272
It also lowers the amps efficiency and raises the current draw.
5
396
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
526
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
Tons of options in that budget, including the cost of installation,
10
721
Ckblood05
Ckblood05
Lambertville mi.
Ckblood05
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
