Tweeters sound distorted (feel like there blown..) when car start
  • 4
rizz06
Hi guys,
i am new in the word of audio system for car, altought i find my way to do everything by myself because i like to understand how thing work together. i came across some problems this weekend after installing my front tweeters,speakers and rear speakers.
I got also everything that i needed for the installation to easy up my work. Everything went smooth regarding the installation and next week iam suppose to get my aftermarket radio and its done. (not sur if ill put and amp)
So my problem come from my tweeters, i notice when i crank my volume the sound coming from them feel like they are blown... but what i dont understant is that they are brand new, when the car is off and i play only the radio they sound and work really good. But when i start the car they start to distort, and i need to lower the volume so i dont ear the distortion. On top of that all my other speakers sound great nothing bad there. Its only my tweeters, something is wrong for sure and i didnt find my answer by looking on different forums.
If anyone had a problem similar to mine, share it its might be my solution.
thanks guys (sorry for the bad english)
Are the tweeters on a crossover? If they are not they are playing to low. That could explain how it works with the car off. They are getting next to no power. With the car on they are getting all the power you have available. If it's a headunit I'd guess all you have is 10-15 watts. Car off is probably under 5 watts.
This is my best guess but at some point i saw noise static issue sounded similar to my problem with the blown speaker ... other common issue i came up was the central point for grounding could be also my issue ?...
my other speaker are not on crossover, that i know for sure... do you thing there is problem ? do you think its might be with the frequencie not distrubuted to the right speaker ? that what crossover is ? and again sorry if i sound noob or so, i can understand how thing work but i need to understand what coponent is for what.
thank again for the support
From my point it can be an issue that your system and the tweeters are not matching properly. That can be a reason why you are not getting the proper result as you thinking to get. So, you should focus on those things. (your system, sub-woofers, tweeter etc)
What are you trying to say?
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
rizz06
rizz06
canada,montreal
LosIsATool
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
