Tweeters with built in inline crossover question.
  • 2
I was looking at running a 2 way setup active using a 4 channel amp using tweets on 2 channels and mids on the other 2. My question is I was looking at the Soundstream tws.3 tweets but it says they come with a built in inline 12db crossover. Does this mean it's got like a passavie cross already or can I bypass it and just use my amp as the crossover?
you can bypass them, just dont put the crossovers in. if you want to go active. have a look at the pics, there is two tweeters and two crossover boxes
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
10K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
HoovaDeuce 82
Ft.Worth, TX
Side Show
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
