Tweeters
Jakerrr
One of my Hertz HT 25's blew and I'm just going to upgrade the tweeters to a new set. Need something that can take a whole lot of power and get loud. Preferably soft dome. Hertz HT 28's would be nice. Anything that can easily handle 100 watts. Must be under 80mm overall diameter. And preferably 4 or 6 ohm
Not significantly but to me I prefer aluminum over soft because I think it has a more accurate sound where soft domes have a smoother sound. It really comes down to personal preference.
I'm using my amp bridged and it is not stable below 4 ohms bridged. Those speakers are 4 ohm IMPEDANCE, but the voice coil resistance (Re) is 2.7 ohms. The Re is the number that matters right? As in that's what the amp sees nominally? Or is it the impedance?
Look at the nominal impedance since its the average the resistance generally seen when it is playing within it intended range. They make it easier to determine the resistance the amp will see with an average since the resistance changes with each frequency played and can vary widely.
The Re is the DC resistance of a voice coil while resting and the Nominal is the average the amp sees while playing.
I suggested the CDT tweeters because they're exactly what you asked for. ES-010 is 2/3 the price and they have a replaceable voice coil assembly for when you blow them.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
10K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Jakerrr
Jakerrr
Lexington, SC
JCE10SQ
