jibberjive 10+ year member
I'm relocating my main and only Optima redtop battery from under the hood to the trunk of my car in an effort to help offset the front-heaviness of my car at the track. I'm going to be putting in an upgraded alty because my system will be running 3000+ wrms.
I've been around a long while and pretty much already know the answer to this question, I just want some confirmation from others before I commit to it: So the positive wire that I run from the alternator in the front to the battery in the rear only needs to be able to hold up to the max that the alternator can put out (in my case around 160 amps), so 0 ga should be big enough for that run from the front to the back, right? My amp will likely draw 200+ amps (Powerbass XA-3000D running just below 1 ohm), but the wiring that I need to worry about for that are the short runs from the amp in the trunk to the battery in the trunk, right?
Anyone see any issues with running 0 ga for the run from the alternator in the front to the relocated battery in the trunk when the system will be pulling more amps than the alternator can put out?
