Unsatisfying output from a 12" FI Q.
I didn't do the wiring of the sub. I had David [TeamPSI] do it, and he just left me with a single wire, so I'm sure he did it right.
What's the easiest way to check it to make sure? Or do I need to take the sub out?
check the ohm load with a dmm, qs should be able to get loud without a problem, have a feeling its at 4 ohms and not 1.
I'll go try that out. I have a fairly cheap DMM that I bought from Lowes. It does get the job done though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. Will report back in a few minutes.
thats a big ass box.
should get down.
where is the gain at?
The head unit I have doesn't have very good pre amp voltage, so the gain is probably pretty high. I'm not sure off the top of my head, I just set it off to wherever the amp would give about 1250-1300 watts.
The gain on my 4 channel amp was just about maxed for the fronts, and only gave me 70 RMS. [52/62 volume].
338
Which amp and which speakers? What crossover are you using? You may be fine so long as you never push the volume too hard.
LinxuS
Jellysickle
LinxuS
Las Vegas
LinxuS
    May 31, 2024
    May 24, 2024
