I need to know how to wire this combo or should i get a 2 channel amp thanks!!
Sub: Kicker Model: 05CVR124
* 12" Subwoofer with dual 4-ohm voice coils
* Suitable for marine use or harsh automotive environments
* Double-stitched, foam-ribbed Santoprene rubber surround
* SoloKon aluminum-treated composite cone with Santoprene surround
* High density ultra-stiff basket
* Power handling: 400 RMS watts (200 watts per voice coil)
* Peak power: 1500 watts
* Frequency response: 20-200 Hz
* Sensitivity: 88 dB@1w/M
* Mounting depth: 6-5/8"
* Sealed enclosure volume: 1.00-2.00 cubic feet
* Vented enclosure volume: 1.75-3.25 cu. ft.
And amp: Audiobahn Model: A8000T
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Semi-Double Sided Glass Epoxy Circuit Board
THD : 0.02%
S/N Ratio > 100dB
Frequency Response : 10Hz - 40Hz (+ / - 1dB)
Variable 18dB High Pass Crossover : 50Hz- 750Hz
Variable 18dB Low Pass Crossover : 50Hz- 120Hz
Bass boost on / off
Subsonic Filter :20Hz - 50Hz
RCA Throughput Connections
3-way Protection Circuitry : Thermal, Short Circuit, Overload, Cooling Fans
Cobalt Blue Illumination
High Gloss Chrome Plated Finish
Nickel Plated Block Terminals
Air Induction Fan Cooled
RCA and Speaker Level Inputs
4 Ohms Stereo : N /A
2 Ohms Stereo : N /A
4 Ohms Mono : 800 x 1
2 Ohms Mono : N /A
Dimension(H x W x D) : 1 7/8" x 9 7/8" x 11 7/8"
