voicecoil wiring options
my amp says its 400rms @ 4ohm n 600rms @ 2 ohm. does that mean it gives out more power when its connected as 2ohm? if it is, must i go get 2ohm woofers?
so what if u have a dual 2 ohm sub and a mono amp that is stable for 2 ohm and i want it to be 2 ohm the diagrams show a total of 1 ohm and then 4 ohm loads so if i want the amp to have a 2 ohm load then would i buy a 4 ohm speaker that will equall 2 ohm to the amp? i thought u had to match the ohms up and the lower ohms the more bass u will get. so then what combo should i do?
ps> im getting 1 sub and a mono amp.
as for your setup, 2 dvc 4s will equal a 1 or 4 ohm load.
1 dvc 4 =2 ohm load.
the lower ohms, the more "wattage" is available due to less resistance. amps don't put out "bass". the sub does.
yea, i don't see how the charts are that complicated.
seriously dude. it just drives me crazy. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
but i think they all expect us to "spoon feed" them..//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
^^got it.. i made a mistake buying a 4ohm sub. gotta go get those other ones. ugh....hate changing stuff n trying to sell the old ones.
i was just wondering if i could wire my subs like this :
so i can obtain a 4 ohm load , the subs are in two seperate boxes
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
104
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
362
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
356
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
4
669
paikiah
Wangaholic
paikiah
Seoul, Korea
tomi
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
