voicecoil wiring options
1 JL 12w6v2 D4
Diamond Audio 600.2 with the following ratings:
RMS Output Power
150W x 2 @ 4 Ohm Stereo
300W x 2 @ 2 Ohm Stereo
600W x 1 Bridged @ 4 Ohms
# Freq Response: 10Hz-50KHz
# Signal-to-Noise Ratio: 102dB
# THD: 0.03%
# Channel Separation: 80dB
# Length: 17"
# Width: 12"
# Height: 2.75"
Can I get 600 to the 12w6? I don't think so.
I cant decide if i'd be better of with a single 15inch d1 sub wired at 2ohms or a d2 wired at 1 ohms. Thoughts?
wellit depends, if its a power hungry sub get the d2 so you can get a 1 ohm stable amp
I went to the Rockford Wizard on the site for help..
well.. I have Three 4 ohm DVC subs. the wiring on the diagram doesn't help.. are they saying to hook one coil to itself? or to hook across from one Coil's + to the other coils -?
sorry if thats confusing, I'll take some pics.. but I did get a result of 2.6 ohms.
But I want to double check my wiring.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
That link is very clear to me. Is there a certain part of it that you don't understand? Each woofer will show an 8ohm load and then with 3 x 8 ohm woofers wired in parallel, that is 8/3=2.66ohm.
Hello everyone. I have a couple of questions, and I was wondering if u guys can help me. I have these subs, 2:
http://www.amazon.com/Kicker-CompVR-07CVR124-subwoofer-4-ohm/dp/B000MSSOWQ/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1232689236&sr=8-1
Kicker 12" 4ohm DVC. So I was wondering if I got 2 of these amps one for each sub ofc, I would get 400 RMs out of those subs theorically.
http://www.crutchfield.com/p_2068ZX4001/Kicker-08ZX400-1.html?tp=115
In the diagram I have 2 ohm, So I would get the actually 400 RMS that the amp has theorically. Would these amps would work just fine. I won't have problems with burn fuses or overheating the amp? ... Thx in advance all...peace..
hi got a lil question... i have one 12" audiobahn immortal qvc 2ohm wired to 2ohm
and a a rockford p3 12" dual 4ohm wired to 2ohm..
the amp is a audiobahn a2300hct 2 channel can i wire these subs to 1ohm or should i just buy another rf p3 .... the amp is stable to 1ohm.... any comments suggestions....thanx in advance...
hi got a lil question... i have one 12" audiobahn immortal qvc 2ohm wired to 2ohmand a a rockford p3 12" dual 4ohm wired to 2ohm..
don't mix subs
233
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
463
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
365
paikiah
Wangaholic
paikiah
Seoul, Korea
tomi
SlugButter
    May 4, 2024
slater
    May 2, 2024
