Volt meter. where to mount?
If you do a nice job and it dosent look like ***** i wouldnt be too worried. sell the car with it when the time comes
ill put some pics up tomorrow. I'm thinking middle console. but i don't want it to be too bright at night.. already got one of my amps power lights (bright blue) bouncing right off the windshield into my eyes... fml.. and the electrical tape isn't holding over it. (vibrations and cold weather)
I disagree with them. Dont go chopping up your car to mount this. If you had a crappy car it would be different. An 09 is only 3 years old, keep that in mind. If you use double sided tape or velcro to mount it somewhere, make sure its not TOO strong because when you pull it off it takes some of the material with it.
I looked your car up online.. it looks like theres a small pocket under your gear selector. BUT, I dont know if thats easily replaceable or not. Im mounting mine in the pocket under my radio since I dont use it, and that pocket is very easily replaceable for about 5$.
velcro or tape always looks ghetto to me. but thats just me. I'd try to find a place to mount it flush that is hardly noticeable, but easy enough to see while driving. I don't think any potential buyer would be opposed to that, it is a good thing to have a volt meter installed.....even though the gauges might already have a voltage meter.
Bahhh grow some nuts and cut a hole... Dnt buy a cheap meter and boom it should look almost stock and is a great feature to have for the future owner of your car. I would have loved it if my car came with a nice one mounted in the dash when I bought it in 04.... As long as u do it clean in no way does it devalue the car at all.
Will come off very easy with 50+%of alcohol that you can buy at the Dollar General Store.Lifts the sticky substance right up , no issues,:naughty:Use smaller sized velcro than the unit, and it looks clean,and not permanent,I did a pair of tweets on a dash in an 87 Toyo s-cab in 89.worked great
Yeah that pocket is fixed to the console. Its one whole piece. Im thinking Velcro. But cutting wouldn't be too bad cuz there is no factory volt gauge.
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Mr.meyhem
Mr.meyhem
Cold as F***, MN
Mr.meyhem
maylar
    Jun 2, 2024
    Jun 1, 2024
